Question about switchbacks
Old Apr 17, 2009 | 09:33 PM
BigTL's Avatar
I've installed switchbacks in my headlights but only one lights when the lights are on. It works fine when I turn on the blinker. The connections are good and solid. Any ideas?
Old Apr 17, 2009 | 10:28 PM
elkechon's Avatar
too much money for
that happend to me.. it can be the buld is bad my opinion is get it exchanged i dont think ur connections are wrong.
Old Apr 18, 2009 | 05:03 AM
JD TL-S's Avatar
I had one go out right away, then another, I ordered another set and they work fine. I sent V-Leds an e-mail and they sent me a return address to return the bad ones.
Old Apr 18, 2009 | 09:49 PM
BigTL's Avatar
You order switchbacks for the turn signals? Do you remember the part number?
Old Apr 20, 2009 | 03:51 PM
BigTL's Avatar
Do you typically have to add a load equalizer to the switchback circuit to ensure the lamp works? Do you add anything to the circuit to slow down the blinker rate?
Old Apr 21, 2009 | 09:57 AM
JD TL-S's Avatar
I will look for paperwork. 48 M-SMT V-LEDS switchbacks require a 6 ohm resistor to slow down the blink rate. Reg bulbs have alot more resistance then LED bulbs. Mount the resistors to steel or an aluminum mounting plate also sold by V-LEDS. I didn't use mine, I mounted the resistors to steel.
Old Apr 21, 2009 | 03:01 PM
6spdtl-s's Avatar
Nismo TL yo!
try switching the defective switchback to the other corner/blinker light connector just to make sure nothing happened to the connector. If it still doesnt work email vleds.com
Old Apr 21, 2009 | 03:33 PM
jmkiang's Avatar
zaino'd
JD, what are those larger switchbacks for?
Old Apr 21, 2009 | 04:53 PM
JnC's Avatar
JnC
Former Sponsor
Those are actually 9006 fog light bulbs .
Old Apr 21, 2009 | 05:25 PM
jmkiang's Avatar
zaino'd
Hmmm anyone have pics of these installed??
Old Apr 24, 2009 | 07:55 PM
BigTL's Avatar
hmmm anyone have pics of these installed??
^^2
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
