Proper motor mount ? Vacuum or no ?
Old Jun 29, 2016 | 03:45 PM
Christopher Dasconio's Avatar
I am ordering new motor mounts for my 2006 acura TL auto
Some of them seem to have vacuum hoses and some do not. Does anyone know which ones I need to order ?
For example on rockauto there is 2 rear ones, one with vaccum hose connection and one without ?
Old Jun 29, 2016 | 03:46 PM
https://www.google.com/search?q=site...hrome&ie=UTF-8
Includes DIY for all mounts and answers your question
Old Jun 29, 2016 | 03:48 PM
Yes, Ive read a bunch of threads on here, but I cant seem to find the OEM parts numbers
Old Jun 29, 2016 | 03:57 PM
Acura Parts | OEM Acura Parts | Factory Acura Parts
Old Jun 29, 2016 | 06:33 PM
nfnsquared's Avatar
Where's the answer to his question about vacuum?
Old Jul 9, 2016 | 08:44 AM
cam_2's Avatar
You need the ones with vacuum ports. I looked into this a while back and contacted Rock Auto, which had this answer: "I called the manufacturer and they stated that [Anchor] Part # 9451 may or may not come with the vacuum port, depending on the supplier. The Vacuum port is not needed unless you have a low idle condition. If you do not have a low idle condition, we cannot guarantee the part will have the vacuum line connection, so you would want to order a part that states it comes with the vacuum port, such as BECK/ARNLEY 1042127. If you do not have a low idle condition, Anchor Part # 9451 will work regardless, and the vacuum line can simply be capped off." I have no idea what that means and had no confidence that I would receive a part with a vacuum port.
The eBay link below was in a similar thread and this listing is at least well-documented:
http://www.ebay.com/itm/SET-ENGINE-TRANSMISSION-amp-SUSPENSION-MOUNTS-FOR-2004-2006-ACURA-TL-3-2L-A-T-/271874174243?&_trksid=p2056016.l4276
OEM part numbers for a 2005 are below and bolts are included since the service manual marks those for replacement:
50810-SEP-A02 RUBBER ASSY., RR. ENGINE MOUNTING (AT)
50820-SEP-A21 RUBBER ASSY.
50830-SEP-A21 RUBBER ASSY.
50850-SEP-A03 RUBBER, FR. TRANSMISSION MOUNTING (LOWER) (AT)
50860-SEP-A03 RUBBER, RR. TRANSMISSION MOUNTING (LOWER) (AT)
50870-SEP-A01 RUBBER, TRANSMISSION MOUNTING (UPPER)
90161-SDA-A01 BOLT, FLANGE (12X45)
90162-SDA-A00 BOLT, SPECIAL (10X34)
90163-S5A-000 BOLT, FLANGE (10X20)
90187-SL4-000 BOLT, FLANGE (10X22)
95701-10045-08 BOLT, FLANGE (10X45)
