Programing 04 TL's keyless remote
Old Nov 19, 2007 | 05:52 PM
ezland00's Avatar
Hello,
i just got my switchblade key and i am trying to program it as mem 1. I got the key programed, but it seem like i didn't get it programed as mem 1 or 2. When i open the door, nothing shows on the display screen. Normally when you use mem 1 key or mem 2 key to unlock the door, it'll said mem 1 is detected. Please tell me what i did wrong.
this is what i used to programed the key
• The system accepts up to three transmitters. The transmitter codes are stored in a stacking-type memory. If a fourth transmitter code is programmed, the code for the first transmitter will be erased.
• Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must
reprogram all the transmitters once you’re in the programming mode.
• You must complete steps 1-6 within 4 seconds of the previous step to keep the system from exiting the programming mode.
1. Turn the ignition switch to ON (II).
2. Press the “Lock” or “Unlock” button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times. Use the same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the “Lock” or “Unlock” button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the “Lock” or “Unlock” button on each transmitter, including the one used to enter the programming mode. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter’s code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
Old Dec 8, 2007 | 02:33 AM
ara606's Avatar
I have the same problem
Any inputs???
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
