Power Steering Whine with sweating outlet?
Hey,
I've been having the temperature dependant power steering whine and I was going to replace the input o-ring. I noticed that the output hose is sweating fluid.. Not sure where it is coming from because it is completely covered but nothing else nearby is.. Any Ideas?
-Jeff
-Jeff
Hey,
-Jeff
-Jeff
Here's the diagram w/ torque for the outlet.
Clean the part with brake cleaner as good as possible and see if you can spot the sweating after some time if it seems to originate from the pump side or the hose side. Not like there's anything higher than that that could drip on it.
Jul 16, 2017 07:33 AM
