Power steering whine (searched)
So i had the typical power steering whine in the mornings when i first started the car, i ordered the o ring and also one of the small hoses that was leaking at bit (my fluid was only slightly low). Yesterday i replaced the o-ring, replaced the hose and drained and filled the fluid with new Honda fluid. Why do i still have the whine in the mornings?! I hate this sound all though its not as loud now but its still there.
Since it was leaking already then you opened it to change the o-ring & hose there'd be some air in it. Did you bleed the air out? I'd start with that.
http://m.youtube.com/watch?v=Wf-_qp1...%3DWf-_qp1y4yc
But looks like bleeding it just requires moving the steering wheel and checking it from what i saw in the video so im just going to do that then check back in to see if thats the issue, i hope i dont need a PS pump.
Ok well i just bled the system out myself since its so easy but when i get out of the car and open the reservoir there is a lot of tiny air bubbles then they slowly dissipate is this how its supposed to be? Currently the car has no noise but then again it is warm so i dont expect the noise until the engine is cold anyway.
You can rebuild the pump for a fraction of the cost.
New pump is about $230 from delray acura (online) or you could buy all of the O-rings and seals for maybe $8 and replace them if it is the pump.
There's a DIY here:
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/
It's a pretty easy job, hardest part is removing and re-installing the pulley which isn't difficult at all with the right tools.
You could also take a look at your power steering rack (near the firewall on the driver's side in the engine bay) and see if it's leaking. Might not be the pump, but if I had to choose between the two the pump is definitely an easier job. Easy to get a look at it while you're doing an oil change with the car on a lift. When they leak they the boots near the tie-rod ends tend to fill with the fluid.
Rack requires the sub-frame to be dropped to get it out and gets real expensive to have a shop do it.
There's a DIY here:
Wow this PS sound has really been very noticeable now even when the car is warm (although much louder when cold) i had no idea it could get this loud. Ordered my PS pump O-rings and seals yesterday and they got shipped today. Im crossing my fingers and PRAYING that this fixes my problem because the noise is just down right embarrasing now.
I bought all the seals and o-rings for the pump im going to install them in a couple days and i'll update you guys. Unfortunately i feel like with my luck resealing the pump wont work and i'll still have the noise in the mornings but i guess we'll see.
mike from annapolis
05-07-2017 08:21 PM
