Power steering whine/groan
Subscribe
Feb 28, 2015 | 10:39 AM
I have air bubbles in the reservoir. At low speeds it groans and is a bit tougher to turn. I changed the inlet and outlet I rings and the problem continues. Is it pump time? It started right after I got the 105k maintenance done. I have read as many posted as possible just wanted to make sure what everyone's thoughts were.
Thanks!!!
Reply 0
Feb 28, 2015 | 02:58 PM
You probably need to flush the whole system. https://acurazine.com/forums/third-g...ewbies-553554/ --> search for "power steering" and you will find DIY threads.
Mine is whining a bit and haven't had time to get to it yet but one thing I would HIGHLY recommend is go to a HOnda dealer and get the reservoir tank as well because the reservoir tank has a built-in filter to collect and gunk in the PS fluid and it cannot be replaced...only a new reservoir tank replacement will do. I think many people may be missing this crucial step because it's not in the regular service/maintenance items. But I got lucky and found some posts mentioning that so good luck.
Reply 0
Subscribe
