Power Steering Pump Replacement
Old Jan 26, 2015 | 02:19 PM
jg_atl's Avatar
7th Gear
Looks like the bearing on my 04 TL power steering pump is starting to go. It looks like the job is not too difficult: unbolt the 2 bolts on the high pressure line, remove the low pressure line that is clamped, remove the serpentine belt and a few bolts and it is out.
Is my evaluation correct or is there something more difficult with this job?
TIA!
Old Jan 26, 2015 | 03:13 PM
Slpr04UA6's Avatar
-------Tim-------
Here ya go! Service manual scans and all!
https://acurazine.com/forums/problem...-scans-841134/
Thanks to Rockstar143!
Old Jan 27, 2015 | 01:38 PM
WDPanda's Avatar
Very easy to do.
But if you don't remove the pulley, you need a flexhead wrench to get to the bolt closest to the front. Best to remove the front then the rear to relieve pressure on the bolt.
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
spidermankb
Mar 5, 2019 11:34 AM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
