Power Steering problem?
2005 TL
When I am backing out of a parking space, or trying to turn going forward, until I get a little speed it is very difficult to turn the steering wheel. Any idea why this is?
My car has/had a leak with he PS fluid, but right before I bought it the previous owner said they had just taken it in to have that hose replaced and I do see a new looking hose connected to the PS fluid.
Not sure if I should replace the fluid or what at this point
I had the exact same problem. My car is in the dealer getting this issue fixed atm. They fixed the leak and the defect a couple days ago but my service rep called me today and said they have to replace the power steering pump as well. I'll report back once I pick up my car tomorrow.
I did this TSB recall in 2007 on my 2004TL and it still does the same thing...I'm sure there's still a leak somewhere since I need to add some fluid once in a while...
Anyway it's not major just frustrating !
I see, well hopefully I can confirm that the apparent leak the vehicle had is gone and then I wont worry about it, it will make my arms stronger!
may be a simple 2 dollar fix, check this video out. i dont have any noise when turning but i do notice power steering fluid residue around my hose so i will be trying this.
http://www.youtube.com/watch?v=Wf-_q...embedded#at=17
My own habits adjusted so that now I almost never encounter this. That being said it did used to worry me--that was 30k miles ago, and no problems today.
Also, ultra-sticky tires don't help the situation.
what color is the power steering fluid? Try turning the tires (drive up on some cardboard) and look at the power steering fluid, is it bubbling?
Also if the fluid looks dirty it might be good to change it out with some new honda fluid.
If steering is hard to turn when parking its because the pump is failing . If you use aftermarket pump sometimes the problem might be the pump. Sometimes you get a bad reman pump . If you are parked and turn the whedl at idle and its hard to turn but when you rev the engine to about 3 k and tutn the wheel and it turns easier then its the pump going bad.
Hopefully it makes sence .
3g tl heavy power steering fix
so iv finally fixed the lack of power steering when i try to park or steer my 2007 tl(190km) at low or no speed. iv tried all if the possible fixes except (ps pump and steering rack) up till last week. Well this week i decided give this issus another go by chamging the ps pump (2 times) just to be 100% sure it was not at fault. Well the pump was not at fault. I seriously considered moving on to the rack but hesitated due to the high cost of part and labour. My mechanic recommended that i avoid this action because he detected no visible leaks and little wear through the unit. So after some more searching i found a thread where it was suggested that the power steering pressure sensor (pss30) might be at fault. This turned out to be a really cheap part so i thought why not. Well 1 week after i got this part replaced, im happy to report that my steering has been a one hand operation even while parking everytime
Still whining!!!
I checked the recall site, my car vin not listed as one but yet its whining. Changed the o rings, whine, changed power steering pump, whine, changed the pressure line hose, whine, added genuine Honda power steering fluid, while. Nothing has worked and I'm out of ideas on how to get it to stop.
did you have a light check engine light
mike from annapolis
May 7, 2017 08:21 PM
