Power Steering Noise when Warm - Bubbles in Reservoir
2005 TL makes power steering whine after engine is warmed up (20minutes of driving), and not before.
I did a search before posting, most articles are about Power Steering Whine when Engine Cold, that goes away when Engine Hot.
Some air bubbles observed in P/S reservoir.
Will the o-ring help at all?
Anyone else have experience with this?
Really would like to avoid the expensive p/s replacement, as they cost around $400
Normally the O ring condition is seen/heard when cold, so I would say that air is being introduced into the system. Check the system to see if any wet spots and make certain all fittings are tight, and it goes without saying, make certain level is correct. If all fails the O ring replacement isn't an expensive test.
samplemonster (05-05-2012)
Received 3,824 Likes
+1 on the o-ring. It was $0.71 for me in FL, test that and if that doesn't help I'm afraid you have a bigger problem.
Will do, I've been putting this off because of grad school's schedule, and noticed the sound is getting worse...
Does this noise (or whatever causes it) progressively kill the power steering pump if unaddressed? I've had it for 5 months now
Will work on this next week during our break.
6th Gear
It's very easy and takes about 5 minutes.
I used this: https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
I'd fix it sooner rather than later. Mine did it the day after I bought the damn thing and I had it fixed within a week.
AZ Community Team
Received 7,771 Likes
A-105: DIY: Power Steering Pump Rebuild
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/ - With Pics and Service Manual Scans
https://acurazine.com/forums/showthread.php?t=754586 - PS Whine Fix (O-Ring Replacement)
mike from annapolis
05-07-2017 08:21 PM
