Power Steering Fluid Leak Again
Old Oct 10, 2005 | 10:02 AM
My power steering fluid is leaking again after Acura replaced the pump last year. Has anyone else had power steering problems?
Old Jan 18, 2010 | 09:43 PM
acuratech123's Avatar
3rd Gear
The pumps do have a problem leaking at the backside. The o-rings also leak which do not require replacing the complete pump. I am assuming you have had the power steering recall performed? Take a peek and see if it is actually leaking from the back of the pump or just the o-ring at the top or at the neck that goes to the reservoir.
Old Mar 21, 2011 | 01:32 PM
moreace's Avatar
Anthracite Trend Setter
What's the best way to test where the leak is from? I don't see anything around where the o-ring goes. I can feel around with a papertowel, but the whole area is dirty and the leak is small.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
