Poor MPG
Old Feb 14, 2010 | 09:29 AM
blue04tl's Avatar
Poor MPG
I know this subject has been talked about numerous times however I get really poor gas milage in my 04TL Auto, but before you answer my question someone tell me is 13-15 mpg in the city (stop and go driving) acceptable. I have done the following to my car seafoam, brand new tires, never run AC or heater, new air filter, and never exceed 3,000 rpm. the dealership told me its nothing wrong with my car which I think is total bull. I had a loaner TL (09 TL tech) and I was easily getting 19-22 mpg. ?????
Old Feb 14, 2010 | 11:00 AM
csmeance's Avatar
do you have any modifications done to your TL? Also check your tire air-pressures to make sure they are at least 32PSI cold. Also what fuel are you using? (Gas station and octane)
Old Feb 14, 2010 | 03:27 PM
blue04tl's Avatar
100% stock, and im running 32psi on all four
Old Feb 14, 2010 | 03:39 PM
csmeance's Avatar
what about gas?
Old Feb 14, 2010 | 09:02 PM
blue04tl's Avatar
used nothing but 93 for two years of owning the car, my previous Acura 2000 TL got better gas milage than this one.
Old Feb 14, 2010 | 11:09 PM
Hi speed's Avatar
runnin a little boost
Look at running higher tire pressures, I was running 40 psi on my stock tires and it was great.
Old Feb 14, 2010 | 11:32 PM
nfnsquared's Avatar
Have you had the car checked with an OBD reader to see if any codes are present?
Are you using a remote start?
Are you using sport shift instead of just letting the AT do the work?
Old Feb 15, 2010 | 12:28 AM
gotkilled's Avatar
NBP is a pain...
my car's mpg has went down significantly as well after using seafoam. i think it's because the spark plugs get a bit "gummed" up after seafoaming and become less efficient. i'm gonna hold out a while till i do my seafoam again before changing the spark plugs.
Old Feb 15, 2010 | 02:49 AM
xxbiggie's Avatar
I have a 05 AT and I get horrible MPG. drive mainly local, and get about the same MPG as you do. Approx. 200 miles for 13 gallons of gas.
Old Feb 15, 2010 | 03:21 AM
gotkilled's Avatar
NBP is a pain...
i drive mainly local as well. before, it used to be around 18mpg to 20mpg but now it's around 14 mpg according to the trip computer after a reset. btw, i noticed that you're from the 626, you should come out to the meets sometime. I like the accord fog lights you have on btw. how hard was it to do?
Old Feb 15, 2010 | 12:17 PM
xxbiggie's Avatar
We had a pretty hard time making it fit good, but that's cause we did it slightly different than others on the forum. Mine sits on top of the aspec lip. i think others have it sitting behind it...
Anyways, my trip computer shows 14-15 mpg as well. sort of sucks
Old Feb 16, 2010 | 01:37 PM
TL on "20"'s Avatar
mine always shown 20 to 21 it was 18 mpg with the 20" rims changed them to 18 and now is always 21. BTW i had to changed the spark plugs because the seafoam damage them.
Old Feb 18, 2010 | 12:43 PM
aussiecar06's Avatar
4th Gear
It must be typical. I get 20 mpg half highway half city. I've yet to be in stop and go traffic. My 98 lexus was getting 24 city and it has 105,000 miles vs. my TL which has 40k. I'll be doing all the good "tune up" stuff to it this spring and we'll see. I've just accepted what it gets.
Old Apr 10, 2010 | 12:56 AM
con5tant's Avatar
will cheapo gas affect your mpg? i started using this gas they have at the local military base and noticed my mpg has dropped dramatically.
Old Apr 10, 2010 | 01:16 AM
gotkilled's Avatar
NBP is a pain...
my gas mileage significantly improved after changing my spark plugs to the OEM NGK iridium laser. i also switched to new 3rd and 4th gear pressure switch sensors. i will get 36mpg on the fwy max and get about 28mpg combined now.
Old Apr 10, 2010 | 07:02 AM
db78's Avatar
Did you do this all yourself? If so could you help lend a hand
Old Apr 10, 2010 | 12:55 PM
gotkilled's Avatar
NBP is a pain...
sure, i could lend a hand. do you have the parts, tools and stuff? i don't want to be liable for stuff but i can definitely give you pointers and stuff.
emailnatec
29
Sep 28, 2018 04:27 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
brocksolid
Sep 29, 2015 12:28 PM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
