poor mans brakes
Old May 25, 2010 | 08:50 PM
soner2nice's Avatar
poor mans brakes
wat up peple just trying to get advice i have a 04 tl auto i think my rotors a warp due to heavy vibrating when brakin at 60 just changed pads but cant afford rotors an cant find a place to cut rotors will it eat up the new pads i put on
Old May 25, 2010 | 08:56 PM
VQPower37's Avatar
just sand down the rotors a bit ... btw wrong generation
Old May 30, 2010 | 06:26 AM
01tl4tl's Avatar
depending on surface
it wont totally eat the pads but will cause faster wear as the pads mate to the rotor imbalances in the surface
when you can get new rotors you will need new pads again
and you will have reduced braking power now
why wont anyone resurface the rotors- are they so bad that cutting them will remove too much material
there is a minimum thickness on rotors- and thats minimum-taking into account the have to last a while before they wear out totally
decent cheap rotors can be found at kragen/oreilly or autozone
Old May 30, 2010 | 07:43 PM
tnassisi's Avatar
6th Gear
O'Reilly will turn your rotors if there is one by you.
Old May 30, 2010 | 09:45 PM
01tl4tl's Avatar
there are many places to get it done- most parts stores for 5 bucks or so
BUT if the rotor is trashed and scored badly- there wont be enough material available after its cut down to keep it above the minimum thickness
if the rotors are too thin- the caliper has to extend farther to push it--everything gets messed up..
then no shop will turn them for you
Old May 31, 2010 | 05:47 AM
Turbonut's Avatar
Rock Auto has front rotors for $29 each, and pads for $20.
Guess if money is that tight, fix the brakes, sell the TL, then buy an inexpensive knock around car.
Old May 31, 2010 | 08:41 AM
Jesstzn's Avatar
Too poor to afford punctuation too? Damn I find posts like that hard to read.
Old May 31, 2010 | 12:54 PM
01tl4tl's Avatar
c'mon thats the fun of interpreting whatever language that was!!
The lack of real information is the problem for diagnosis on this one
whats wrong with the rotors- did OP wear the brakes down to zero MM pad and gouged the rotors.. as they were literally metal to metal to stop the car?
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
brocksolid
Sep 29, 2015 12:28 PM
