PO174 Code 04 MT
Old Jan 31, 2014 | 03:26 AM
BxTrini_TL's Avatar
PO174 Code 04 MT
Does anyone have a part number for this o2 sensor i would need to change? Thanks!
Old Jan 31, 2014 | 08:26 AM
Vlad_Type_S's Avatar
Registered Bike Offender
How do you know it's the O2 sensor? There are other things that can cause that code. I'm only asking so that you don't go spend your money on unnecessary parts.
Old Jan 31, 2014 | 08:31 AM
Do you have any other DTCs? If not, then you should perform the troubleshooting steps in the attachment from the service manual. I also got this code and a valve clearance adjustment fixed it.
You can reset the PCM without an HDS by disconnecting the negative battery cable for like a minute.
https://acurazine.com/forums/3g-tl-2004-2008-93/resetting-your-ecu-after-mods-environment-changes-631749/
https://acurazine.com/forums/3g-tl-problems-fixes-114/how-can-we-restart-pcm-685919/
Old Jan 31, 2014 | 11:55 PM
BxTrini_TL's Avatar
https://acurazine.com/forums/showthread.php?t=631749
https://acurazine.com/forums/showthread.php?t=685919
Thanks for the reply bro. There isnt any other DTC popping up. I cleared the light and it hasnt come back on yet. If it does come on p0174 only again i will go ahead with the o2 sensor change im getting it for $120 at Honda. I just need to know the exact part number so i know im getting the right sensor.
Old Feb 5, 2014 | 12:00 AM
BxTrini_TL's Avatar
so i cleared my code and today cel popped on again for po171 and po174 could this be caused from a vaccume leak?
Old Feb 5, 2014 | 08:04 AM
Yeah, that's possible. You also might need a software update. I don't think the TSB specified the 2004 model years, but I would take it to a dealer and make sure it's up to date just in case.
If it still comes back, I would start with the fuel pressure. I think if anything else was wrong, you would get a different DTC also.
Old Feb 6, 2014 | 02:35 AM
BxTrini_TL's Avatar
ok do they charge you for a software update? I have a friend thats a tech at Honda, he said mostly likely a vacume leak. But I will take it to the dealer as soon as this snow stops.. Thanks
Old Feb 6, 2014 | 03:27 AM
^Vacuum leak sounds like it can certainly cause this, especially on both banks now (got worse?). Honestly, I don't know enough about how the ECM/PCM uses all the sensor input to throw these codes. The manual says check fuel pressure first and makes no mention of a vacuum leak so I am forced to assume that one of the other DTCs on that list would be thrown if there was a vacuum leak. This is all theory and I'm going to stop rambling now.
The software update is like a 0.2 hour labor charge per the TSB. So it's not free, but it's pretty cheap still. If you're a regular at that dealer, they might do it for free. Or you can try to negotiate. I'm willing to bet that they've probably fixed/improved a few other things since then so the software addresses more than just the sensor input usage.
Old Feb 6, 2014 | 07:27 AM
Slpr04UA6's Avatar
-------Tim-------
Originally Posted by hohmst1
There is a TSB for this. It states that the PCM system needs to be updated. I recently took my car to the dealership to get timing belt serviced and it was $60 to have it done for me. Outdated PCM system causes vehicle to run lean. This may be your issue
This is the TSB from another thread.
Old Feb 6, 2014 | 11:12 AM
Haha, I knew it. Doesn't apply to 04-06 models. Well go in anyway and see if there is one.
Old Feb 7, 2014 | 01:40 AM
BxTrini_TL's Avatar
thanks guys for the info. will keep you posted
Old Feb 7, 2014 | 04:22 PM
youngluda97's Avatar
Hi there I was sitting in a parking lot today and my 07 type-s popped the p0174 all by its self. looking at the service bulletin should i go to the dealer or what advice can be given mine appears to only be bank 2.
Old Feb 9, 2014 | 12:59 AM
BxTrini_TL's Avatar
Yea you should go and update the software anyway.. Software update is only for 07-08 according to my local Acura dealer.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
