Piston 2 Mis-fire 04 TL 6sp
I was wondering if anyone else has had this problem...
Piston 2 is sending off a check engine light reading that it is mis-firing...
I reset the light, start the car under cold conditions and it does not come back on. Each time with the AC turned off...
The last two days it has been hot and I have left the AC on and when I start the car, the check engine light is on.
Any suggestions? I swapped the coil from piston 1 to 2 and it still reads piston 2 is bad. Spark Plug the issue?
SidhuSaaB
05-30-2020 12:40 AM
acuratl26
04-23-2020 07:30 PM
