Pin-pointing bad mounts
Old May 20, 2009 | 04:50 PM
vinuneuro's Avatar
If you have too much vibration in the cabin, how do you figure out which mount(s) specifically are bad? I understand the front one is a common failure, but the vacuum hose is attached fine and I don't see any fluid leaking out of it.
Old May 21, 2009 | 12:18 AM
240sx acura tech's Avatar
acura master tech
put the car in drive a hold the brake pedal. rev it to about 2200 rmp real fast on and off.
if you hear a thud or pop there broken.
Old May 21, 2009 | 12:48 AM
vinuneuro's Avatar
No thud or pop, but there's quite a bit of movement when that's done in reverse and drive.
-In reverse, the front of the motor goes a lot.
-In drive, the rear of the motor goes a real lot.
-When you shift into reverse, the front of the motor moves a bit and a loud clunk.
Old May 21, 2009 | 01:59 AM
vinuneuro's Avatar
*meant to say:
-In reverse, the front of the motor goes down a lot.
-In drive, the rear of the motor goes a down a real lot.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Froid
Sep 27, 2015 06:16 PM
