Phillips Screws on Rotors?
Hello,
I'm still new to Acura's and learning as I go. Tonight I did pads and rotors on my 04 Base TL. I stripped one of the phillips screws that hold the rotors on and did not replace it. Can someone tell me if that will cause any problems?
AZ Community Team
Received 7,770 Likes
They are not necessary. They are to hold the rotor in place during factory assembly.
Lots of 'em get stripped and the heads drilled out. There are no issues if that's what you need to do.
AZ Community Team
next time you guys remove these use the proper tool and you wont strip them out.
Something like this. You smack the end with a hammer while turning. The screws will come right out no problem.
Something like this. http://www.harborfreight.com/impact-...ase-37530.html
GKinColo08TL (01-19-2012)
the overexplainer
I bought the tool only to find that my rotors had been replaced before and the screws were missing -_-
anyway, that tool would come in handy doing other stuck bolts.
AZ Community Team
Or not:
Just drill them out and it doesn't require a left handed drill bit either. Just drill the head off enough to remove the rotor then use a pair of vice grips to unscrew the rest of the screw. Took less than 5 minutes per side.
the overexplainer
also if you have a a regular hammer and a ball peen hammer, you can just use the ball end of the hammer against the screw and smack the ball peen with the other hammer and you should be fine.
I broke 3 grabit screw extractors trying to get those damn screws out. Grabit makes the Craftsman version also. I just drilled them out. I did replace some of them with a new metric screw from True Value. I am anal like that.
The screws were totally infused to the surrounding metal.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
