Passenger side window sticks/wont roll up
One on the right for me
When I put the passenger side window all the way down and then try to roll it up using the driver side commands the window will go up two inches, stop, and then roll back down. The only way I can get it to roll up all the way is if I pull up real fast on the switch, otherwise it sticks and then goes back down. Anyone else have this problem. Car is going back to the dealer again (this and because paint on the door is peeling/cracking)
Originally Posted by dmjones82
My window does the same thing. It does not happen all the time. It has happened four times. I drive a 2004 TL. I have not taken it to the dealer for the window.
i actually just got back from the dealer today about it....they said it was a faulty window regulator and its fixed under warranty.
I have the same problem happening to the passenger side window but not constantly. Like you said, when i open the window all the way down then bring it back up, it goes up about 2-3 inches then goes back down by itself. Did they replace the regulator on yours?
marcelft
07-10-2018 06:17 PM
sockr1
10-01-2015 01:31 AM
