Passenger power window will not roll down
Old 06-01-2012 | 10:55 AM
jeffbags's Avatar
Lightbulb Passenger power window will not roll down
I cannot operate the passenger side powered window with either the driver side or passenger side controls. When I press the control button I can hear it making a click but nothing happens. Do I need a new motor or has anyone one had any experience with this issue that was resolved with a simple fix that did not involve replacing the motor?
Thanks for your help!
Jeff
Old 06-01-2012 | 11:33 AM
Biggi_e's Avatar
FRESHINNOVATION NBP TL-S
could be your actuator(sp?) gone bad. or maybe the window came off track. you can always pop off the door panel and check
Old 06-01-2012 | 11:41 AM
TWiSDiT's Avatar
Chapter Leader (Mid-Atlantic Region)
Jeff
I had the exact same problem. In addition, the window actually fell down and it wouldn't stay into place. I had to duck tape the window up until I got it repaired. Replaced the power window regulator and it fixed it.
Old 10-23-2012 | 07:18 PM
floorit's Avatar
I'm having the exact problem with the driver's window. I checked the fuse but it's fine. Just get a click sound from the switch area. Any thoughts? Thanks
Old 10-23-2012 | 07:22 PM
floorit's Avatar
I just realized that Twisdit posted that his was the regulator. Is this a difficult project to replace and roughly how much is the part? Thanks.
Old 01-24-2014 | 06:04 PM
tabularasa's Avatar
05 TL 6MT
I had this exact same problem 6 months ago. I replaced the regulator and it started working perfectly. Now, its broken again. What are the chances the regulator is bad again just after 6 months? Same symptoms, clicks, but window does not move.
Thoughts?
12-07-2020 05:39 PM
02-25-2020 09:57 AM
09-17-2015 09:01 PM
09-15-2015 06:44 PM
k6biv
09-10-2015 06:37 PM
Quick Reply: Passenger power window will not roll down
