passenger door window
Old Nov 8, 2009 | 07:04 PM
bbailey's Avatar
6th Gear
having a problem with my pass door window. when i go to roll it back up, it comes up about two inches then goes right back down. it does this multiple times (from either drivers door switch or pass door switch) it will eventually go back up after i keep trying it. Any ideas??
Old Nov 8, 2009 | 07:26 PM
Will Y.'s Avatar
Registered but harmless
Welcome to AZ.
There was a Technical Service Bulletin regarding the window tracks/channels- the dealer would either clean & lube the tracks or disassemble and reassemble the tracks, etc. depending on the extent of the problem.
TSBs can be found in the 3G Garage- see http://www.in.honda.com/Rjanisis/pubs/SB/B06-031.PDF.
Other members had window regulators replaced for the same problem, but I'd try cleaning and lubing the channel first.
le^2
Mar 17, 2026 05:06 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Brandle34
Sep 23, 2015 07:20 PM
spoiler900
Sep 23, 2015 04:41 PM
