Passanger side seat heater not working
Hi all,
I've been looking around online on this issue without success.
My passenger side heated seat is not working since i bought my car 2 years ago.
The light in the switch does light up but no heat is ever generated (i know back is not heated).
Could it be a fuse? if so which one?
Could it be the cable disconnect under the seat? if so which one/where?
If not what else could it be?
I'm hoping its not the actual heating element as the replacement looks quiet long.
Thanks for your help!
MM
MM
check the fuse but I highly doubt the fuse, I going through the same dilema on my TL too.
rockyfeller (02-02-2015)
King of NYC
Been meaning to do this. My driver's side bottom cushion has no heat for the longest time, (most important reason to have heated seats!) everything else works. I'm sure it was one of the couple times I removed the seat for installs back in the day. The harnesses are all plugged in. I guess I have to do the continuity test.
Registered Bunny
rockyboy
01-25-2016 06:00 PM
