Parking brake making werid noise
Since yesterday I noticed my parking brake making clunking noises whenever I set it after putting my car into neutral. Is this normal or can I get it fixed under warranty?
I put the car into neutral and then hand brake and then into park. It never did this clunking noise before and only started yesterday.
Are you sure the car isn't actually rolling back slightly when it's in neutral? I've had that happen before (it's kinda like a thunking sound - somewhat alarming) and it was because I didn't pull the parking brake enough to get it to hold the car in place.
Registered but harmless
Received 1,102 Likes
It sounds as if the parking brake is severely out of adjustment and may not be engaging when you pull up the handle. Have it adjusted (usually done automatically w/new brake pads) and see if that resolves your problem. Independent mechanic > Acura dealer, FWIW.
rockyboy
12-06-2022 02:29 PM
