p0420 and p2272 simultaneously
Old Jun 25, 2024 | 08:48 PM
Zin123's Avatar
Question p0420 and p2272 simultaneously
Hi guys,
Its my first post so please bear with me here and feel free to ask questions. I have a 2007 TL-S M/T with two engine codes: P2272 and P0420. I have had the p0420 code for quite a while but I tested the associated sensor (I cant seem to remember which one it was a long time ago) and all seemed okay with it, so to avoid buying a new cat I decided to ignore it. Now however, I have gotten a P2272 code as well and I have decided I want to clear both codes. Are they somehow related and only need 1 part to fix both codes? I can't seem to find a clear answer on what sensors to replace so I figured to make a post of my own and get some more advice. I understand that these codes could be completely uncorrelated but any advice to clear this up will be greatly appreciated. (If it helps the car smelled a little rich before the p2272 and now it's smelling a little more lean)
Thanks guys,
Zinoviy
Old Jun 25, 2024 | 09:02 PM
https://acurazine.com/forums/3g-tl-p...sensor-885946/
You might be able to get away with just replacing the o2 sensor (bank 2 sensor 2) make sure you get NTK/OEM
https://www.rockauto.com/en/moreinfo...=5132&jsn=1165
This should be b2s2 if i'm not mistaken
TheSauceBoss
Oct 7, 2023 11:08 AM
Acura7880
Dec 15, 2015 04:22 AM
TLS_TXKing
Apr 19, 2015 01:12 PM
6spdLEGEND
Oct 21, 2001 07:07 PM
