P0404 and more
P0404 and more
I have a 2006 RL. It burns 3 to 4 quarts of oil per month. Blue smoke out the exhaust when I start it. EGR valve gets carbon caked in it and I have to clean it out every couple months. Now is also throwing P0300 through P0306 codes saying each cylinder is misfiring. Engine runs rough. Is this related to the oil burning? Engine codes started suddenly and the car was running fine previously.
According to your symptoms you have oil leaking into the cylinders. Might be your piston rings are fried but definitely a seal/gasket/ring is the problem.
HAve you tried running a compression test on the cylinders? That would help you isolate the problem to a specific location.
Billu99tl
09-13-2015 11:30 AM
