P0302 Engine Code
Old Jan 9, 2009 | 10:57 AM
4DGSR's Avatar
P0302 Engine Code
I was wondering what type of fuel injectors the 2004 TL uses. Peak and Hold or saturated. And what are the CC? I think I need to replace them.
When I start the car, it will idle fine but when I drive off, and reach the stop sign at the end of the street, the idle drops below 1 and stalls on me. Every once in a while, I will get the check engine code p0302 saying that I have a misfire.
I thought about the seafoam but I don't think that will help.
I have 83k miles on the car. The last 20k all freeway.
Old Jan 9, 2009 | 11:07 AM
nfnsquared's Avatar
Misfire on cylinder #2. Could be a bad/loose coil pack, could be an injector, could be spark plug, could be worse:
http://www.obd-codes.com/p0302
Google is your friend.
Old Jan 9, 2009 | 12:58 PM
01tl4tl's Avatar
80k miles -I would change the plugs out with NGK Iridium (same as stock) and run seafoam (before plug change) thru the intake manifold and gas tank.
and buy 1 coil- try it on each cylinder till the car runs right, thats the most frequent cause of misfire code. BUT there may be a TSB on this issue at the dealer
If changing the plugs- the odd looking oil wet one had the bad coil- put the new coil on it!
make sure to reset the ECU so the computer can run self test and relearn without a misfire
Its possible this is covered under the emission warranty- it wont pass smog right now and is under 5 years old--check the warranty, call acura 1-800-382-2238 x5
and go speak to the service manager at your dealer
Old Jan 9, 2009 | 09:18 PM
csmeance's Avatar
are you using premium fuel?
Old Jan 9, 2009 | 11:50 PM
ssmtl2nv's Avatar
2009 g37s 6mt
if not you should consider using 91+, I use 93 shell v power and she loves it...
Old Jan 10, 2009 | 07:18 PM
NABeast's Avatar
The easiest way to determine a coil problem is switch it to another cylinder and see if it codes for that cylider. A valve adustment can cause that as well,but usually isn't a problem until they get over a 100k.
Old Jan 12, 2009 | 12:30 PM
4DGSR's Avatar
Thanks. Yes I am using the 91 octane. Changed the plugs about a month ago. Went away for a little bit but came back. Swapped coil 3 with coil 2 so we will see if I get another code. I also put in a can of seafoam.
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
