P0134 cel
Old Dec 22, 2010 | 03:04 PM
dontTL'em'nothing's Avatar
riding low and steady
P0134 cel
did the research to find out that its the o2 sensor and from my scanner read " 02 circut no activity, (bank 1 sensor 1)"
all i need to know is which 02 sensor is it? i read in a few post it said in front of the engine and another post stated it was near the firewall? i just need the clarifcation. TIA
Old Dec 23, 2010 | 12:39 AM
nfnsquared's Avatar
Bank 1 is the rear set, sensor 1 is the top sensor (A/F sensor). I'd reset the code and see if it happens again before spending money on a sensor...
Old Dec 23, 2010 | 10:25 PM
yea i already reset the code with the scanner twice. comes back almost immediately. havent really noticed any change in mpgs. believe man i aint trying to spend money unless i have to. But its important for me to have everything running soundly because im expecting a baby soon.
Old Dec 23, 2010 | 10:34 PM
nfnsquared's Avatar
In that case, looks like it's either a loose connection at the sensor or ECM/PCM, or a bad sensor.
Old Mar 11, 2011 | 03:49 PM
mgiles's Avatar
6th Gear
I have a 2006 TL with a P0134 reading. I have checked the connections and they appear firm. I have cleared the code several time but the code reappears quicker each time. So, it sounds like a O2 sensor needs to be replaced.
1) Can someone confirm that the bank 1 sensor1 means it's the rear (meaning near the firewall) sensor?
2) The front sensor and rear sensors appear to be identical. Of course, the rear sensor is much more difficult to access. Is it possible that the large structural bar that is in the way of accessing the sensor can be removed?
Old Mar 11, 2011 | 04:09 PM
nfnsquared's Avatar
Originally Posted by mgiles
...1) Can someone confirm that the bank 1 sensor1 means it's the rear (meaning near the firewall) sensor?
Yes, it's the rear, top (upstream) sensor. Bank 1 means the bank attached to cylinder #1 exhaust...
Yeah, strut tower bar comes off, 3 nuts each side, two bolts on driver's side, 1 bolt on passenger side. Retorque the nuts to 21 ft-lbs??
Old Mar 12, 2011 | 08:00 PM
mgiles's Avatar
6th Gear
Thanks nfnsquared.
I removed the srut tower bar and replaced the sensor. After clearing the code all seems well.
The hardest part was unclipping the socket and loosening the old sensor. With the help of a good neighbor, both were accomplished.
All seems well after about 35 miles of driving.
Old Apr 22, 2013 | 07:47 PM
mrfreshh's Avatar
Im having the exact same problem!
i have an 05 TL and my codes were coming back P2251 & P0134
Someone told me the light would go away if i changed the front sensor thats visible right near the radiator fan
DONT change that one!!!
I changed it, turns out now it only reads 0134 and the damn light is still on!
So im guessing P0134 is the rear top one near the drivers side and under the strut bar? Correct me if im wrong please but this problem and the stupid check engine light is driving me crazy lol
Old Feb 14, 2014 | 09:24 PM
umakemekissu's Avatar
would anyone please give me the part number for this bank 1 sensor 1? i'm looking
Old Sep 21, 2019 | 02:04 PM
mekuanent24's Avatar
Hey were you able to get the part number?
Yikes
May 3, 2021 04:29 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
