One high beam not working
I just changed out my HID bulbs. Now my passenger side high beam doesn't work. When I flick on the high beams the drivers side projector opens up and I get the full light, but no such luck on the passenger side?
Does anyone have any ideas what could be wrong? The low beams work just fine.
The DVD-A Script Guy
So you know, there isn't a separate filament for high beams. It's just one filament ant there's a shutter in the headlight assy that moves when you switch to high beams. You may not have seated a connector all the way back on or somehow upset the shutter mechanism when you changed out the bulb.
Google --> "site:tl.acurazine.com hid shutter" without quotes found
one high beam shutter won't flip --> https://acurazine.com/forums/3g-tl-problems-fixes-114/one-high-beam-shutter-wont-flip-776727/ Perhaps the fuse is your issue. Check that first for sure.
rockyboy
01-25-2016 06:00 PM
