Is it OK to drive with ABS warning for a few days?
Hello, I recently blew out a tire, and was driving around with the spare for 2 days before getting it replaced. During those 2 days of driving with the spare, the ABS warning light went on (it didn't go on initially when I blew my tire). I've called my mechanic to see if he can investigate it, but he says that his code reading machine won't be back for another 5 days. So I'm thinking that whatever is wrong is probably related to the ABS, not the regular braking system. Since the weather is great right now (in the 70's, no rain in sight), I thought it would be OK to use the car for another few days.
But I found a list of ABS codes (http://honda-tech.com/showthread.php?t=978933). I don't understand them all, but some of them seem to refer to regular braking function.
So my question is whether all these ABS codes are all ABS-related and therefore low risk for me to drive for another few days, OR, are some of them potential problems to the regular braking system in which case I would find a mechanic ASAP?
Thanks in advance for your advice.
if your abs light is on. That means your ABS isn't working.
It's off for some reason, Could be a wheel sensor issue.
I drove the my car around with the ABS light on for about 5-6 months until I got the chance to replace my wheel bearing.
I don't see any problems with driving with the abs light on.
Also, you need a scanner that can read ABS codes.
something like this
something like this
My ABS light was also on but I got the wheel bearings replaced and I also got the ABS sensors replaced since they were bad on my car, cables chipped and stuff. Normally that light comes on due to brake issues.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Jan 25, 2016 06:00 PM
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
