Oil on rear spark plug in '08 TL-S
Old 08-22-2015 | 09:33 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
When I went to go replace the three rear spark plugs on my 2008 TL-S, one of them, the rear one closest to the driver, had some oil on it. I tired to get as much oil out of the spark plug tube as I could.
Do I need another valve cover gasket? What could be the cause of oil in the spark plug tube? I just passed 100K miles.
Old 08-23-2015 | 03:32 AM
YeuEmMaiMai's Avatar
remove upper intake
remove valve cover
replace tube seals
reinstall valve cover
reinstall upper intake
Old 08-23-2015 | 01:39 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Originally Posted by YeuEmMaiMai
remove upper intake
remove valve cover
replace tube seals
That's, I'm guessing, roughly 1.5-2.5 hours of labor for a moderately skilled person.
Old 08-24-2015 | 10:34 PM
truonghthe's Avatar
its more on the 3.5 hours depend on the front or rear bank, its similar to to do a valve adjustment minus the replace the tube seal.
Old 08-25-2015 | 02:55 PM
it took me about 3.5 hours to do mine... and less than 2 to do an accord I4
Old 08-25-2015 | 03:02 PM
thisaznboi88's Avatar
you might as well do a valve adjustment while your there
Old 08-25-2015 | 03:08 PM
truonghthe's Avatar
yup, while you have everything off, make sure you buying a good shim kit.
Old 08-25-2015 | 06:08 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Yeah,
I'm probably going to have the dealer do this and add it to the timing belt service.
Old 08-25-2015 | 06:56 PM
truonghthe's Avatar
expect paying around $2200 for dealer price.
Old 08-25-2015 | 07:34 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
For 2.5-3.5 hours of work?!
Old 08-25-2015 | 07:48 PM
do the TL have the issue where the water pump was not machine correctly and make weird noise?
Old 08-26-2015 | 03:08 PM
truonghthe's Avatar
no that price is all for TB/WP along withe the tube seal, the tube seal alone will cost you around $550.
yeah they did for the early 07 model, however mine is one of early early 07 model, sticker said Oct 06 and did not cause the noise described as TSB.
Old 08-27-2015 | 08:43 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Hmmm. If that's the case, I might have to take a stab at the tube seal. If I just have to take off the strut bar, all associated hoses from the intake manifold, take off the air intake, and then take off the rear valve cover, that could be worth $500 right there to me.
Old 08-27-2015 | 07:07 PM
truonghthe's Avatar
I could get it done under 4 hours for both bank, however I got a lot of experience by working to clean the dam EGR passage on my old Accord J30A1. All you need is a day in the weekend to get the job done.
Old 08-27-2015 | 08:23 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Yeah, I guess I could do that myself, just have to keep track of all the hoses, wires, nuts and bolts that I take off. I'm very anal ( ) so that should not be a problem.
Old 08-28-2015 | 02:19 PM
truonghthe's Avatar
keep us updated on the price then.
Old 08-28-2015 | 09:09 PM
where are you located? maybe I can do some freelance job
Old 08-29-2015 | 10:35 AM
truonghthe's Avatar
^^^OP living NoFlo.
Old 08-29-2015 | 05:27 PM
damn. I should move to FL. there another guy looking for a TB change also. lol Good luck if you decide to DIY
Old 08-29-2015 | 07:52 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I'll probably replace the tube seals and valve cover seal myself. I'll take it to the dealer for the TB and water pump replacement. I can get that done for $900.
Old 09-04-2015 | 03:35 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Valve adjustment only needs to be done when something is wrong or a code is being thrown.
mada51589
05-03-2022 09:54 PM
IIDXholic
10-08-2015 08:53 AM
Laoch
1G RL (1996-2004)
10-02-2015 04:27 PM
Aleax
09-11-2015 12:31 PM
NSolace
09-03-2015 09:14 PM
Quick Reply: Oil on rear spark plug in '08 TL-S
