oil reading
It's no limit Baby
oil reading
i just pick up a used 04 TL from a the dealer the other day before i picked it up the stealership did an oil change and i notice it read 90%,fast foward a week later and now its reading 80% and i barely drive the thing, is the TL suppose to burn oil that fast?i have a 06 civic and my oil meter doesnt go down that fast
Thus, it can literally go from 90% to 80% in one mile.
How much oil you "burn" (probably none) has nothing whatsoever to do with the oil life algorithms that result in the oil life display.
They may have forgotten to reset the indicator- its a DIY
The lifespan should equal 7500 miles of normal driving- on average
synthetic oil you can go longer
New filter at halfway point good insurance
If its like gen2- we put key in ignition- push and hold both trip reset buttons and turn the key to ON- that resets the oil minder
Yours should be similar idea
The TL has a sensory system that can sense the way you drive. So if one drives crazy and fast, their oil change indicator will come on sooner, usually within 3k miles. But if one drives slow like me, then it may go on for about 5 or 6 thousand miles before the indicator may come on. Moda, no need to worry, like Harddrivin says, it's the increments, that's why it went from 90% to 80%.
Registered but harmless
Received 1,106 Likes
bump, i know someone knows how to reset this
The MID reset issue shows up often, so the mods put directions into the 3G Garage:
https://acurazine.com/forums/showpos...73&postcount=4.
A search for "maintenance display reset" would likely find threads leading to the directions as well.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
