Oil pan change
Oil pan change
Im trying to replace my oil pan because there is a small drip coming from the drain plug. I'm looking online and found a replacement oil pan. i just wanted to know if the is a difference between the base model 6mt or the type s 6mt and what i should be looking for
Registered but harmless
Received 1,106 Likes
When you changed the oil, did you change the crush washer between the drain bolt and the pan?
If not, buy one (actually, get a few-- they're 14 cents each or so) and install a new one to see if it'll stop the leak before messing with the oil pan.
Be careful not to overtighten the oil drain bolt, too.
If the drip is from a messed-up thread, you might see if a Heli-coil will work instead of changing the pan.
