Oil pan change
Old Jun 15, 2012 | 01:40 PM
DANELSON's Avatar
Oil pan change
Im trying to replace my oil pan because there is a small drip coming from the drain plug. I'm looking online and found a replacement oil pan. i just wanted to know if the is a difference between the base model 6mt or the type s 6mt and what i should be looking for
Old Jun 15, 2012 | 03:01 PM
Will Y.'s Avatar
Registered but harmless
When you changed the oil, did you change the crush washer between the drain bolt and the pan?
If not, buy one (actually, get a few-- they're 14 cents each or so) and install a new one to see if it'll stop the leak before messing with the oil pan.
Be careful not to overtighten the oil drain bolt, too.
If the drip is from a messed-up thread, you might see if a Heli-coil will work instead of changing the pan.
Old Jun 15, 2012 | 10:14 PM
DANELSON's Avatar
i think it was over tighten
foxriderar77
Nov 19, 2020 10:17 AM
kmarqueling
Oct 3, 2015 01:14 AM
Aleax
Sep 11, 2015 11:31 AM
Allen_442
Sep 8, 2015 06:01 PM
