oil leaks
oil leaks
I have 06 TL /at, while changing oil today, I notice the pass. cv joint connected to the trans is leaking at that seal. So how hard is it to change that seal? Does it just pop out after I remove the cv shaft? Thanks for all the help! Son.
Do you see a rip? if not then you might be able to just replace the boot & repack it. If there's a noticeable rip I would replace the whole driveshaft. New shafts are $70 / shaft at Advance Auto Parts w/ LLT.
IBankMouse
06-13-2020 12:53 PM
