Oil leaking on top of engine,help!!!!
Old May 30, 2014 | 02:51 PM
Amin68's Avatar
3rd Gear
Certainly there is oil leaking under the small black plastic cover in front of oil dipstick as picture shows. Not too bad, not sure what is the problem,probably is old oil seal or o-ring .
I am new ziner here,does any one have the same problem? Or anyone know which part do I need change and the part number is? I am 2006TL,thank you.
Old May 30, 2014 | 02:55 PM
Amin68's Avatar
3rd Gear
Tight the 10mm bolt as tight as it can,still leaking.
Old May 30, 2014 | 07:09 PM
Hi speed's Avatar
runnin a little boost
It's called a PCV valve, was $18 a yr ago.
Old May 30, 2014 | 09:10 PM
Amin68's Avatar
3rd Gear
You are right bro,now I know the part NO. is 17130-RCA-A02. I will go get it soon and replace it,it's easy job!
Thank you so much!
mada51589
Jan 9, 2025 04:40 PM
IIDXholic
Oct 8, 2015 07:53 AM
datadr
Sep 12, 2015 09:12 PM
winkyyy
Sep 11, 2015 04:40 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
