O-Ring
Old Jan 7, 2018 | 10:38 AM
2001CLCoupeLife's Avatar
O-Ring
I've been trying to remove the bolt to change out my power steering o-ring but it's been a hell of a task to remove. Any suggestions on trying to get this bolt out?????
Old Jan 7, 2018 | 10:39 AM
guitarplayer16's Avatar
Breaker bar will crack it loose. tip: applies to any bolt that feels difficult to remove.
Old Jan 7, 2018 | 10:04 PM
champaned_out's Avatar
buy some pb blaster at home depot and soak the bolt down, wait 5-10minutes and try again
Old Jan 8, 2018 | 08:28 AM
Hit the gym more, use a cheater bar to increase leverage, or get a higher torque impact tool.
Old Jan 8, 2018 | 12:51 PM
LightKiosk's Avatar
Are you referring to the bolt that's part of the DIY A-105, part number 91345-RDA-01?
If that's the case, I had to use the 16(?) pointed side of the 10mm wrench that's round. It bends away a little bit, giving leverage to get it in there. Trying to use the other side with the opening didn't give me the leverage or angle I needed.
Old Jan 9, 2018 | 03:38 PM
WDPanda's Avatar
You need an angled wrench.
Old Jan 10, 2018 | 11:34 AM
GhostTL09's Avatar
popeye spinach
