So I just replaced the cv axle. Now whenever I turn right there is a noise that sounds like the tire is rubbing on something. the faster I go, the faster the noise gets. Can post a video if needed, any idea what this could be?
if it sounds like something is rubbing, chances are something is rubbing. take a look at the car and figure out what is rubbing. we cant see the bottom of your car from the internet
So for some reason the noise just went away. Still not sure what it was. On another note, I will NEVER be using a scissor jack again. Damn thing just collapsed. Luckily the only thing that was damaged was the dust shield behind the rotor.. And yes I know I should have been using stand and put the tire under the car.
howd you get it off the ground after that? haha. glad you still have all your limbs
Quote:
