Noise when accellerating
#41
Mine did happen when the car was cold and between 2,000-2,500 RPM. I have an '04 with about 83,000 miles on it. Adjusting the heat shield did fix the rattle problem. Under hard acceleration I would always hear it, and I've gone 2 days now without hearing it at all.
You can kind of tell that it's the heat shield making the noise because it sounds like a metallic rattle just at a real fast pace. Sort of like fast pinging noise of metal on metal.
#42
Just an update:
The noise hasn't come back and I've been back under the car to repair the stripped bolt. While under there I realized that you shouldn't really have to remove the exhaust to get at the heat shield nut that you need to tighten down. If anyone else tries this repair I would suggest trying to to position the heat shield against the bolt/nut that is most easily visible and just tighten that nut down. It should fix the problem without having to pull apart anything else.
#43
I have this same problem. It buzzes/rattles when I accelerate. Very annoying. I can also hear a buzzing when I kick the front passenger tire while the car is parked and the engine is off. Sounds like something is loose. Hopefully it's just the heat shield.
#44
e92 335i
why is that im suddenly having this same problem? For me it also occurs even if the engine is just idling, much worse when accelerating between 1500 - 2500 rpm.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
