Noise when AC is turned on
Old Aug 25, 2012 | 10:49 AM
VanyDotK's Avatar
I wasn't getting a response in the other thread so hopefully I get something here!
So I get a squealing noise around the serpentine belt area when I turn my AC on in 100+ degree weather. I've had the tensioner and belt replaced less than 10k miles ago. It only happens when the fan and AC is on. If the AC is on and the fan isn't on, it won't do it. Just a side note I have a UR stock sized pulley, but I don't think that's the problem.
Here is the video, around 51 seconds I have my fiancee turn the AC off and back on for comparison purposes.
Any ideas?
Old Aug 26, 2012 | 01:24 AM
mindanaomoro's Avatar
..kinna hard to tell, if you said you've replaced the tentioner/pulley and the serp belt. It could be your alternator?? The reason I said that because I was having the same noise that it only comes on when the AC kicks in, but some times it doesnt make the noise. I left it alone while I was waiting for the tensioner to arrive, but not long after that my alternator failed and once I replace it the noise went away, then the F** tentioner arrived the next day and I didnt even need it...
Old Aug 26, 2012 | 11:53 AM
VanyDotK's Avatar
Thanks for the suggestion, I'll take it over to autozone and have them test the alternator this afternoon and report back.
Old Aug 26, 2012 | 03:11 PM
VanyDotK's Avatar
The alternator tested fine, back to square one.
Old Aug 26, 2012 | 05:01 PM
pohljm's Avatar
It can still make noise under load and pass testing
Old Aug 26, 2012 | 08:44 PM
VanyDotK's Avatar
I may just have to wait for the thing to die then, I have the extended warranty and I know they won't replace it until it's dead.
BigDogues
Jan 18, 2022 11:35 AM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
PortlandRL
Sep 14, 2015 12:01 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
