Noise/Vibration at idol
Old Sep 26, 2012 | 04:41 PM
njkode's Avatar
As the title say, I notice a vibration/noise when I am sitting in idol. Its even worse when the A/C is on. It gets frustrating, if I rev then engine it takes the vibration away.
It bothers me so much that I turn my A/C off if I am stopped at a light.
Any one have any ideas? I was thinking it could be the engine mounts I plan to inspect them this weekend when I have some time.
Car is an 0 TL-S, I bought it used last summer and this has been there the whole time.
Old Sep 26, 2012 | 04:51 PM
Catfisha's Avatar
Giant Blue Car
What are your RPM's at idle? (As opposed to, Billy Idol )
Old Sep 26, 2012 | 04:54 PM
Ruby's Avatar
US Navy Seabees
How many miles are on the car? What year is it? Maybe you need a valve adjustment or maybe you need a motor mount.
Old Sep 26, 2012 | 05:03 PM
njkode's Avatar
damn typo's
74k miles and its a 2007
Old Sep 26, 2012 | 06:30 PM
TLRD's Avatar
I have a lil of this as well.. Let me know if you come to a conclusion. Subbed for fix!
Old Sep 26, 2012 | 09:00 PM
MandoTL's Avatar
I have a similar issue.
But I did a valve adj. and no fix which brings me to the Serpentine belt, I notice that one of the tensioner pulleys wiggles compared to the rest that just rotates in perfectly straight order.
I will check the mounts also this weekend.
Old Sep 26, 2012 | 09:21 PM
Dubs_0's Avatar
I have the same issue. When I turn the car on sometimes it makes the sound, when I hit bumps or pot holes, or even on idle depending how the car is angled, my town is mostly hills. When I rev the sound leaves. After reading a few threads I thought it was the mount. Had the car lifted and checked it out with my dad who's a mechanic and its a lower control arm bushing on the passenger side. Luckily It's covered in the warranty so I save a few bucks. Not sure if its the same but worth checking maybe?
Old Sep 27, 2012 | 09:18 AM
nismopowerdqg's Avatar
LowNslowTL
Check your motor mounts!
Old Sep 28, 2012 | 11:39 PM
MLB's Avatar
MLB
7th Gear
I just fixed this issue with my TSX. It was definitely the motor mounts. Be sure to use the factory replacements - I tried cheaper replacements, but it just made the vibration worse. Replaced with factory mounts - now idles like a new car.
Old Sep 29, 2012 | 11:50 PM
1black_seven's Avatar
Slot Machine Lubricator
same problem here.
For me colder weather seemed to aggravate it further.
Replacing motor mounts solved the problem.
urbaita1
Nov 28, 2006 11:53 AM
