No Start, No Power, Nothing!
So here's the story:
I just got back from vacation today, tried to unlock the doors with the remote... Nothing. That's happened multiple times before (after about a week of not being started), and jump starting it always resolves the issue. This time, I didn't have jumper cables (well, I do, but they are in BAD shape). I called AAA. They came out, tried to test everything and get it to start with no luck. He tried jumping it with the jumper box <--- not sure what it's really called. He also tried jumping it straight from his truck. Anyway, still nothing. I have no lights (even when he's got power to it), doors won't lock/unlock, etc... He said it may be a fuse, but that he couldn't tell and I'd need a tow to a shop and so on. I'm really not sure what to do... I'm not a car expert, but I do know a thing or two about circuits and electronic systems (CS/EE major currently).
Thanks for reading, and I hope I can get some suggestions! Thanks AcuraZine
TLDR: TL won't start, maybe I need to throw it away?
Battery was changed in 2010. Doesn't seem like it could be a bad battery because even with cables connected to a good battery, I get nothing... I'd think I'd get at least some lights, because wouldn't that just be supplying sort of "artificial" power to the system?
Hmmm... I don't really have a way to get it to AutoZone. Can I just run a test with a voltmeter? I thought the AAA guy said he was able to get like 2 amps running through it. From an electrical standpoint, this should be MORE than enough to power running lights or something.
amyz2005RL (09-16-2019)
Voltmeter is at my parents house... No luck there. Today is going well :P I guess I could make one, but that would just tell me if there is any power, not how much. Also, in my previous post I said Amps where I meant volts... I don't know how to edit posts on this forum.
You can't edit posts on this forum after a few minutes, for whatever reason.
If the battery was bad, a jump would show it. The car should show signs of life, unless the battery is really shorted inside. Even then, the car would likely react in some way, or you should at least notice a gigantic spark when you connect the jumper cables.
Standing voltage on the battery isn't terribly useful. The remote door unlock should take such little power that it should work in most any situation. If that's doing nothing, with jumper cables properly connected to a running car, you have an issue somewhere.
I'd check the ground. You could wiggle it, or inspect the connection to the chassis for corrosion, or measure for voltage between the - on the battery and the engine. It should be near 0, if you are reading near battery voltage, you have a bad ground. Of course check all fuses as well if the ground is good.
The battery should read about 12.6V unloaded, fairly charged. Below about 12.2V and it's in bad shape, but most electronics should show some signs of life, it would just be a questionable start.
Just realized I forgot to post the picture! The part I colored red is the part I'm talking about that "might" be bad, but I can't be sure. The part in green looks fine.
I had to lol at your response. Did you just skip down and hit reply after only reading the title? Anyway, yes... I have tried to jump start the car, and I don't think it's the battery, but I'll try replacing the battery if nothing else works.
EDIT: Just called Acura and they can't get me the part until Friday. Is this a fuse I could find at the auto parts store?
I doubt you could find that anywhere aside from a dealer.
The top link sure looks bad enough to have popped, I would imagine the solder should appear to be nice and smooth like the other one. However, it didn't exactly explode, and its hard to tell if its broken in that picture.
I would ohm it out, make sure its open. Or try to pass some current into it if you have a power supply, random load, and some clip leads. Probably going to need to get that from a dealer. It's probably called a 'fusible link' rather than a fuse.
tl_cody (07-24-2012)
Well, I guess I'm stuck till Friday. I'll have to get a multimeter when I can get to the store. Tough fixing things when it's the car that's broken. And nothing here is within walking distance.
The following 2 users liked this post by laziebun:
justnspace (07-24-2012),
tl_cody (07-26-2012)
Just grabbed a cheap-o continuity tester... Continuity in the bottom, but not the top as we had suspected. Hopefully just replacing the fuse (when it comes in) and jumping the car will do the trick. If not, I'm lost.
Good News! The new fuse did the trick! They run about 16$ from Acura (if anyone else ends up having the same problem). Thanks for all the help everyone.
The following 2 users liked this post by tl_cody:
csmeance (07-20-2022),
PoppyChuLo9305 (08-20-2021)
Role model
Wow, crazy. This happened to me today. Can I ask some questions?
That picture above....where is that fuse located? Is it in the box where the cable from the positive of the battery goes to? If so, which one is it?
My car died at the airport and the attendant crossed the cables. I ended up having to jump from the fuse box and drive on all alternator power. I changed the battery and the terminals, but am not getting a circuit, so I suspect that the same thing happened to me.
So yea....if you could tell me which fuse that it, I would really appreciate it. I was thinking that I would have to replace the battery cables, or something.
Thanks in advance
Thanks in advance
Role model
But here's another question. If I could jump from the fuse box but not the battery, then the fuse must be good then, right?
What could be the problem? Battery cable?
My 06 tl just crapped out this morning at 4a.m. On the way to work. I stopped at the gas station to fuel up and grab some coffee. 10 minutes later I get into my car started it and it just shut off in like 2 seconds! Tried starting it and no power at all, I mean no lights, radio, horn, door locks, remote, trunk, etc. anything electrical wouldn't work. Left the car and got a ride from my stepdad came back after work and getting a ride from my buddy which is a honda technician. It's 7pm now and we took that battery fuse out and guess what it's blown. Couldn't tell until we shook it around and heard bits dangling in there. Took it apart and yep it's busted. So let's hope acura or honda has this fuse in stock tomorrow and I'll buy two just in case there is a ground short somewhere.
part number
Do do you have the part number for the fuse? My 2005 RL did the same thing this weekend and I fixed it by jumping the circuit with 2 10 gauge wires and a 100a fuse. I'd still like to get the correct piece back in the block but cannot find it anywhere
I had the exact same issue off and on for about 1 year. I had replaced my starter, battery. I finally took it into Acura dealership and they replaced the negative cable going to the battery. Seems like when it was wet outside the car would act up more. The cable cost about $50.00 from Acura but you can probably find one cheaper online. The symptons of my issues were sometime car would start and ask for input the Navigation code, sometimes the radio code, sometime the car would not turn over, other times the car was completely dead (no horn, no locks), it seemed if I would let the car sit or hit the break peddle the car would act normal again. I could sometimes take the car out of park and move to neutral and back to park and sometimes it would then start. I have an Acura 2005 MDX and I hope this helps someone in the future with these simlar issues
My rdx 2013 got same problem today, after not drive for long time due to Coronavirus. I jumped the car correctly, but now dead. How to jump start in the fuse box, so I can drive the car home first?
Does your rdx has main fuse? One between positive battery terminal and rest of the car? Probably like a 120A one. If it does, then that is what likely went bad.
If that is the case, it's better to bypass that fuse than to jump start from the box. Without the battery, there is nothing in the system to stabilize the alternator's output and bad things might happen.
What’s the name of this fuse ? Same exact thing happened to be and I’m trying to order a new one but legit don’t know the name of it and battery fuse isn’t popping up what I need
It looks like #5; Fuse A, Multi Block (120A/70A) ; Fuse Holder on the parts diagram below:
If it is, the part #38231-SFY-003 is in #31 BreezyTL's post above.
Search that part # and vendors will magically appear.
In addition, beware of rip-off knock offs offered on the interwebs. IMHO, I'd pay the $$ & get an OEM part.
