NO OUTside temp display!!!
Replaced my front bumper with an aspec front and now cannot get the outside temp to read! Does this make sense?? The dealership did the replacement a while ago, but I just noticed it. What should I do?
steeez
adding the aspec kit shouldnt do anything to your temp readings...
has it been really hot in your area? i have an 04 TL and when the temp outside is above 115, the car reads --- but once it cools down below 115 it will get a reading again.
Registered but harmless
Received 1,148 Likes
Get under the car, check for loose wires to see if that is the problem.
If it's a bad sensor, you'll have to have the dealer or an independent Acura mechanic diagnose and replace it.
ITSJESTER
17
12-06-2018 02:29 AM
2005, 2006, acura, display, displaying, find, gauge, mdx, rl, sensor, temp, temperatue, temperature, tl, tsx
