No electronics, not starting
Hello, I have a 2005 Acura TL 6-speed manual. It sat for about a week and when I tried starting it nothing happened. No electronics, no sounds whatsoever, nothing. This even occurs while being jumped. I've replaced the battery cables and still nothing.
I think you should still get the battery tested. Perhaps your battery was so drained that even a jump-start was insufficient?
You're on the right track to solving it... if replacing the cables didn't solve anything, definitely check out the battery
You can also unhook the battery and hook up the jumper cables to see if the lights will at least come on. Do NOT start it like that, just see if juice is flowing.
