No ac / hot air
Old 08-23-2018 | 06:01 PM
madara187's Avatar
7th Gear
No ac / hot air
hey guys I just joined and new my English isn’t great I apologize but a friend of mines referred me here that been a member at acurazine for quite some time... recently I hit a speed bump couple days ago and my ac stop blowing cold air.. Now it’s blowing hot air I try recharging / adding Freon but I can hear a hiss sound while it was recharging like it’s leaking Freon.. I also check my compressor it seems like it is locked but I’m not sure.. what do you guys suggest? I google everywhere I can’t afford to go to mechanic and fix it since I’m on a budget
Old 08-24-2018 | 07:46 AM
frankjnjr's Avatar
FWIW: If you can hear it leaking, " I can hear a hiss sound while it was recharging ", you should see evidence of Freon, at the point of the leak. If you can't locate the source of the leak, you may want to try charging the system with a UV equipped Freon, which would make it much easier to pinpoint the leak.
A/C Pro UV Leak Detection Kit - Walmart.com Also look at YouTube videos for related info.
Old 08-24-2018 | 09:18 AM
BreezyTL's Avatar
I agree, I would try to locate the source of the leak first. Then figure out what's next. Best of luck with the repair!
Old 08-24-2018 | 10:28 AM
madara187's Avatar
7th Gear
Thank you for the fast replies guys I will look into it this weekend I hope we will solve this issue with my tl 💪🏽
187_FAQ
12-27-2004 03:43 PM
Zapata
06-04-2003 07:13 PM
BSK181
08-09-2001 05:16 PM
