new member
Old Aug 16, 2017 | 01:34 PM
johnathan112usmc's Avatar
6th Gear
new member
Found a Type-S a couple days ago that it needs some TLC. So far the Bluetooth isn't working and I have the tighten gas cap error going off constantly. Does anyone know of other things to watch out for . This car has almost 171,000 miles. interior not so pretty needs a lot of diligent cleaning and conditioning. Other than that I feel like I got a pretty good deal. The car I got is in the profile picture.
Old Aug 16, 2017 | 04:44 PM
Ron A's Avatar
Administrator
Welcome to the forums.
Since you are hardly a "new member", and this is a technical issue which will require replies and not a "New Member Introduction", I moved this thread to the appropriate subsection so you can hopefully get more help.
Old Aug 16, 2017 | 07:59 PM
truonghthe's Avatar
The HFL module is very common thing to break in the TL next to the gas cap warning, I own 2 TLs a base and a Type S and they both have the same issue.
HFL unit can be bought at AZ OEM parts vendor for $256 + $89 - $190 core deposit (once you complete replacement send the old one back along with copy of purchase receipt and they will issue a refund)
Gas cap warning can be address very easy (there is multiple DIY in this forum) $90 part + 10 mins of your time and tools needed for the job are 10 mm socket and pliers. It simple as disconnecting to vacuum hoses and remove a 10 mm bolt and 10 mm nut.
