New J-Pipe installed-now vibrations!
Hey AZ, turning to you guys for some help as last resort. I ordered the XLR8 v2 jpipe from Josh last week and it came in the mail yesterday. I installed it the same day using all hardware provided. Problem now is intense vibration felt throughout the cabin, seats , mirror and steering wheel. Can be felt when in gear and worst when i turn on the heat/ac and fans kick on at a stop. I rechecked all bolts, hangers, reinstall and everything is tight and aligned. This morning i went to a local mechanic who specializes in hondas/acuras to double check the work. He also loosened all bolts, realigned and tighten everything back. He said the jpipe along with my catback ( comptech ) is much lighter than before so vibration is going to occur. Im out of ideas, id hate to go back to my oem jpipe but if this vibration cant get remedied then i have no choice.
Note: all engine/trans mount are like brand new (oem), they been replaced 4-5 months ago
Please help
Please help
MMkay.
No codes? As the driver of your own vehicle, can you tell if it's coming from the suspension/body or the engine bay? My thoughts are the hangers might be loose or even unhooked depending on who did the swap. There is a " U " bracket that holds the J to the body and sometimes those bolts break. The J pipe may be just swinging side to side.
The fact that you say it worsens at a stop when you place the A/C on etc, makes me feel like a misfire of some sort, or a clogged cat.Although this will usually trip a DTC.
Try putting the OEM one back on and see if the problem still occurs. If the OEM pipe fixes the problem than I would suggest contacting Josh and asking for a refund or exchange for another j-pipe maybe the one you have could be defective or faulty.
That's what I would do.
Is it bareable?? I need to record a video of a half filled water bottle on the passenger seat to show how intense mine is lol..
I'm gonna have some else take a look at it. My car had no vibrations with the oem jpipe. Worst case if I put the oem one back on and it fixes it.. Be on the look in the bm
^I get slight vibrations on the steering wheel and in the gas pedal. Sometimes it doesnt bother me but then others i just dont want to drive my car. I am going to reinstall the oem j pipe this weekend if i get some free time if not then next week. I will let you know if the problem gets solved.
MrHeeltoe
20
02-23-2023 01:54 PM
ExcelerateRep
10-14-2015 08:20 AM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
