new acura tl owner - "D" Flashes; Seat Mem Dead
hey club whats up?
well am new here so ill be clear on my question hope you guys can help me
first: the manual transmission is not working but the automatic is working well only there's a light blinking ON
posicion D on the gauges when is back from the manual shift
2:the engine light is off all the time even on the posicion key posicion on
3:the memory seat dead is not working!
thanks guys!!!!
thanks guys!!!!
A flashing "D" is an indication of a transmission problem or code.
What year is th car? Where did you buy it (Acura dealer, other dealer, priviate purchase)?
Is there any warranty? Is it a clean title or a "salvage" title?
Could be a sensor or switch in the manual/sport shift mode.
Really may need to go to an Acura dealer.
.... The ‘‘D’’ indicator comes on for a
few seconds when you turn the
ignition switch to the ON (II)
position. If it flashes while driving (in
any shift position), it indicates a
possible problem in the transmission. ....
For the seat memory, check fuse #20. If your windshield washer doesn't work, then it's definitely a blown #20 fuse. There is a TSB for this to replace fuse #20 with a 10A fuse instead of 7.5A.
Both of your problems are discussed in existing threads. The search function works well and will allow you to find the info you're looking for rather than start new threads.
ok i got my pin shift module today i call acura dealer to fix the problem the want 89.99 for the part and 139.99 for the labor total 229.98 plus tax 13% . i buy the part by acurapart.com i pay 38.99 plus shipping 22.99 total 61.98 THE best part i change by my self its working and am superrrrrrrrrr happy
asahrts
09-04-2015 05:55 PM
