Need some serious help.
Old Jun 24, 2019 | 09:59 AM
Gordon Edjhill's Avatar
5th Gear
I have a 05 TL At and I replaced the tranny with a 97k tl in May because I had a bat torque converter. Now I have been driving at highway speeds and I see the tacko meter would stay at 2 and would not drop even after I take my foot off the acceleration and sometimes it would even over Rev without even hitting the X and at that moment I would feel a light lost of momentum but if I hit the X it would be very fragile.. Can I please get some help. In addition I have been trying for a while to get my vsa and triangle light off is there any relationship or any solution..
Thanks for the read guys your help would be appreciated?
Old Jun 24, 2019 | 10:22 AM
t-rd's Avatar
What transmission did you replace with? A junkyard unit? A rebuild? A reman? And did you change the trans fluid?
Old Jun 24, 2019 | 12:30 PM
5th Gear
I changed it with a tranny from one of my friend tl and yes I changed the fluid.
Old Jun 24, 2019 | 01:32 PM
It's bad. Replace it with one from an Accord V6 (06-07)
Old Jun 24, 2019 | 02:56 PM
5th Gear
Hi I was thinking about that can u direct me to the specific honda acord that has good trannies because I was searching online and there is so many variables like 5 digits, Japan built etc?
Old Jun 24, 2019 | 02:57 PM
5th Gear
Old Jun 24, 2019 | 04:23 PM
t-rd's Avatar
Your friend's transmission is BAD. The only thing you should ever do when swapping the trans for 3rd gen TL and 7th gen Accord, is to have it rebuilt first at a trans shop with the Translab shift kit put in which fixes the root of the problem, valve body issue that causes the torque converter to overheat. It's basically a waste of time and effort if you just swap one from somebody or picked from a junkyard, because the root problem is still there. And if you get a reman without the valve body fix, the problem will appear again when the trans gets more miles again.
Old Jun 24, 2019 | 04:51 PM
5th Gear
OK thanks. I guess I already made that mistake I just have to wait till it goes dead on me again or try to sell it before.
acn684
Apr 27, 2006 11:57 AM
abouelmm
Apr 7, 2006 12:54 PM
MrGQDieselNY
Sep 12, 2004 09:26 PM
