Need some help with SRS DTC 3-1, 3-2 and 8-1
So long story short. I bought a vehicle with a flood title. Saw pictures of the damage and there was a dinner plate size puddle in the driver foot well. Water never got to any electronics. I've been driving the car for almost a year now with zero issues except the srs light is on. So I'd like to take care of it.
When I bought the car, the srs light was not on then on the way home it suddenly came on. The driver seat was unplugged (power, srs etc). I assume the place I bought the car from never plugged it back in after drying the carpet.
So now I have srs DTC 3-1, 3-2 and 8-1. I replaced both side impact sensors just in case they got wet since they sit so low and tried resetting the srs light. No luck.
So I need some advice. What exactly are the codes and what do they mean? Don't want to be rude, but please spare me the "it's a flood car". Nothing got wet. Appreciate any help you guys can provide.
Well first off 8-1 means internal failure of the SRS unit.
Secondly the reason the SRS light is on is because the key was put in the ignition without having all of the seats/seat belts plugged in.
You're going to have to take it to the dealership to have them reset the SRS light with their HDS tool. Should cost you $100-120. No other way about it. Your airbags won't deploy with the SRS light on. The "closing circuit" diy reset method doesn't work with these cars. The computer has to be plugged into the HDS tool.
mille_3 (09-14-2013)
Many auto parts stores will rent you the tool. Gotta look around though. Where I'm at, only Oreillys will rent you the OBDII/CAN/SRS tool.. it is like 400 bucks, but you get the money back when/if you return it. And yes, if any of the components are unplugged while the car is turned on it will trigger an error code.
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
