Need Recommendations on a Bank 1 Rear Cat Converter Replacement
Old Feb 20, 2012 | 11:05 AM
BlacAc06's Avatar
5th Gear
Hi Guys,
After noticing my Check Engine Light coming on, I took my 2006 TL (AT) into Acura only to find out that my rear, bank 1 cat needs to be replaced, however they quoted me $1100. I did some research and found that the rear bank 1 cat is bolt on, not weld, and also I can get it online for about $200. Does anyone have any suggestions on the best replacement for this cat and why I should spend $400+ on an OEM part from Acura vs. buying the $200 part onine??? Thanks!
Old Feb 20, 2012 | 11:17 AM
Turbonut's Avatar
Normally an OE cat will last a lot longer than a cheap replacement.
What was the code that caused the CEL to light?
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
IIDXholic
Oct 8, 2015 07:53 AM
