Need help wit tranny
Old 03-24-2017 | 12:43 PM
sereous lee's Avatar
8th Gear
i have an o4 Acura TL n I can't shift back to automatic only thing it's letting me do is shift for drive 1 to 4 no rough dear changing our nthn everything seems fine except that n the the letter d is blinking. I'm in manual mode even wen I startup up. HELP HELP HELP HELP
Old 03-24-2017 | 01:12 PM
jzhu625's Avatar
you need to read what you typed, it does not make any sense, it's hard for people even try to help
Old 03-24-2017 | 01:38 PM
sounds like your transmission is in limp mode.. hows your fluid levels? when was the last time you did any maintenance like change the pressure switches. Do a search on here for said pressure switches and you'll see a huge thread regarding it.
Old 03-24-2017 | 01:47 PM
8th Gear
Obviously he understood what I was sayin but my bad this is what happens wen your working n tryna get your point across lol
Old 03-24-2017 | 01:49 PM
8th Gear
it's seems like it's correcting it self by goin into manual mode after the d4 stops blinking
Old 03-24-2017 | 01:50 PM
8th Gear
hasn't been a year yet since is changed the fluids
Old 03-24-2017 | 01:51 PM
i've been around enough to translate a lot of bad posts you should work on stronger posts if you need help though.
Old 03-24-2017 | 01:52 PM
how many miles in the last year? with these transmissions, i would do no less than 15K fluid changes.
do the pressure switches as well. Blinking D light is not a good sign.. chances are your transmission may be on its way out.
Old 03-24-2017 | 01:53 PM
8th Gear
I'm looking for help not the grammar police👮
Old 03-24-2017 | 01:55 PM
people can't help you if they can't understand your problem
but feel free to ignore the advice and see how many responses you get!
8th Gear
no rough shifting or none of that the d4 has blinked like that b4 wen I first got it last year n it would ony do it wen I go into manual mode n it lasted this long. Only thing different is I can't get out of manual mode lol
Old 03-24-2017 | 01:57 PM
8th Gear
I'm sure u can read my responses to the other guy but do u have any advice? If not then✌️
Old 03-24-2017 | 02:16 PM
jzhu625's Avatar
peace!
Old 03-24-2017 | 02:32 PM
Slpr04UA6's Avatar
-------Tim-------
Seriously?
I dont think anyone is tryin to be grammer police, it's just very hard to understand what your trying to say. Thoiboi was trying to help ya.....
Old 03-24-2017 | 02:59 PM
8th Gear
Originally Posted by Slpr04UA6
Seriously?
do u have any advice or not it's obvious we have already cover that part of the conversation
Old 03-24-2017 | 03:57 PM
NoTLoud's Avatar
Old 03-24-2017 | 10:43 PM
Jackass's Avatar
I have read this thread 5 or 6 times today....and my head still hurts trying to completely understand the symptoms and what has already been tried. So far I read that it won't shift into 5th? Something about b4 the d4 wit blink rough manual shift?
No matter what....follow the typical TL auto advice....new fluid, new pressure switches, and hope for the best. Although this issue may be a tad different and have some other electrical culprit hiding.
Old 03-25-2017 | 12:29 AM
01acls's Avatar
Car get parts check go blinking now else something ok. AFS readable OBD2 dealer not probably only. Address sure first checking make trans.
The following 2 users liked this post by 01acls:
Jackass (03-25-2017), SocomM4 (03-30-2017)
Old 03-25-2017 | 08:33 AM
i couldnt understand the OP...
but if OP needs a new tranny,buy a new tranny,OP!
Old 03-25-2017 | 06:53 PM
nfnsquared's Avatar
Tranny help? Here ya go:
Transsexuality
