need help........cel....
Old Dec 13, 2010 | 07:46 PM
cabesa's Avatar
Cel came on last week for po420 catalyst system effciency below threhold bank 1 I went to advance and had the light turn off and put a gas treament a week later it came back on....any ideas.......please help.....
Old Dec 13, 2010 | 09:19 PM
nfnsquared's Avatar
Bad gas can cause that code. Assuming you are sure that that is the only code, then I'd reset the code and run a whole tank of good gas through the system first.
According to the service manual, if that is the only code and it keeps coming back, it's a bad CAT on that bank (rear CAT).
Likely, it's either a spurious signal (they do happen), it was caused by bad gas, or you have an associated code along with it (bad A/F or O2 sensor)....
Old Dec 14, 2010 | 08:38 AM
cabesa's Avatar
It when thru a few tanks of gas since the first time it happen. And I think the dealer change the o2 sensor about a year ago for a different problem it had....
